AlienALX
Well-known member
That would be a good idea. Like, clock limiting them on older boards.
In theory VRM should reach a certain temp, then throttle the power output. Unfortunately if this is poorly implemented you end up with a fire lol (glares at MSI). However, when implemented properly in a decent bios it's perfectly safe.
I had three 8320 set ups in the end. The first was on an Asrock that was awful (4+1). However, the second was an Asus M5A97 something and that was only 4+2. However, it was very clever in so much that if you set the voltage any higher than 1.35v it would simply refuse to try and output it. Meaning you could safely clock an 8 core to around 4.3ghz or so remaining completely safe. Which was cool.
Then of course I had the Crosshair, and that thing was just nuts. That really did tap out CPUs haha.
