g0ggles1994
Active member
Hi everyone
Recently, I've built a new machine running a Ryzen 1700X and an XFX RX 480 GTR (non Black Edition) and I've been getting constant stuttering when doing any form of gaming on it, even if I have an FPS of over 200. It runs smooth for a second or two, stutters and then repeats which as you can imagine is absolutely infuriating.
I've done a re-seat in the PCIe slot, changed slow, running the newest motherboard BIOS, checked the PSU cables, different outputs etc and no luck. The only thing I've had luck with is rolling back to the 16.12.2 driver which hasn't stopped the stuttering, but has made it not as bad.
Has anyone had a similar problem? Or have I got a "soon to be" dead card?
UPDATE
Fixed (thank you SPS) it was actually F.Lux causing it, enabled Safe Mode on f.lux has fixed it as well as obviously disabling or removing it
UPDATE
