Afternoon/Morning fellow OC3Ders,
I'm looking to upgrade my RIG on ideally a £550 budget (£600 the absolute max)
Current Spec:
AMD FX 6200 Intending to replace, seems to be acting up, can't see core temps on HWmonitor
Gigabyte GA-970A-UD3P
Corsair Force GT 90GB
Powercolor 5750 1GB needs upgrading!!
2x4GB Corsair XMS3 1600MHz
1TB Samsung SpinPoint
Some random 320GB HDD
Powercool 550W Intending to replace, it's loud as fuck on full load
More Info
It would help if the GPU was compatible with a full-cover block, as I intend to water cool in the next year or so. I am no huge gamer, don't have the time. Although from May I have 4 months off from Uni, so wouldn't mind getting some game time in. Would like to play at high to ultra settings with at least 50 FPS at 1080P. Lastly, I'll be looking at cclonline.com and/or scan.co.uk
My thoughts already
I'm personally looking at a FX-8350, I'm sure most will agree. Can't upgrade the motherboard as that was a gift.
I'm looking for a 280x, 290 (non-reference obviously). Mainly so I can mine away from my PC. Throw me some options here!
Also thinking a Corsair RM 650 will be ideal, due to the absolute silence (550 would work, but the 650 is only £3-£5 more expensive. Open to other options. May also get myself some of the individually sleeved cables eventually that are available.
So with that all in mind I suppose the GPU is the most essential upgrade to decide on (280x, 290), and as said before the FX-8350 is the most obvious CPU upgrade. As for a PSU, I have my eyes on the RM series either the 550 or 650. Plus the individually sleeved cables are a bonus which I shall take advantage of in due time.
Cheers in advance guys sorry for the long read
J-a-c-o-b
Current Spec:
More Info
My thoughts already
J-a-c-o-b
