Review of the Thermalright Ultra 120 eXtreme by TMDD
Whilst CPU’s continue to get faster, more power efficient and cooler, the heat sinks bolted on top of the CPU continue to get bigger. The cooler features heat pipes to dissipate heat away from the processor into the tower block where the heat gets transferred into the fins. Thermalright have chosen to use heat pipes because in fact it’s the world’s most effective air cooling solution to date.
Today, we have the Thermalright Ultra 120 eXtreme in our hands and we’re about to put it through its paces.
A little bit about Thermalright;
Company info
Thermalright is an elite design house that manufactures cooling products for computer components for the best quality and performance your money can buy. In 2002, AMD released its first generation Thunderbird CPU and since then we have been there every step of the way to counter high voltage and high heat with innovative design and highly acclaimed cooling solutions not only for AMD but for Intel as well. One of early well known solutions was the SK-6. With many positive and rave reviews under its belt Thermalright bolted to the top as the heat sink manufacturer mostly preferred by Overclockers and enthusiasts around the World. To this day, innovation never left our vocabulary as we keep coming up with leading edge designs staying ahead of the competition
Taken directly from Thermalright’s website – last accessed on Saturday, 29th November 2008
Specifications
Dimension: L63.44 x W132 x H160.5mm (Heatsink Only)
Weight: 790g (Heatsink Only)
Recommended Fan: All 120mm Fan
Quiet and powerful cooling due to multiple heat pipes and large aluminum fin area
Proprietary bent winglet design to minimize airflow resistance
Heat pipes soldered to base (nickel plated)and fins for optimum heat transfer
Include both bolt-thru-board retention brackets for Intel and AMD
Specifications taken directly from Thermalright’s website – last accessed on Saturday, 29th November 2008
Packaging
Unfortunately, the packaging the cooler came in is far from exiting. First impressions based on the box were quite a letdown but let’s not let it put us in a negative mood!
Once the box was opened, we got pleasantly surprised. Faced with the cooler packed very securely in foam. All the accessories that come with the cooler are in the box underneath the Thermalright sticker.
Once the items had been taken out of their boxes, we can see it is all wrapped in plastic. This is to protect the cooler from moisture during transport. The items in the white box are also enclosed in plastic because it keeps them all together; it also helps to stop the components rattling against each other and causing damage.
The cooler
First impressions gathered from the cooler is that it is an extreme solution, hence where eXtreme dictates itself from the name of the product. Simply amazed by the sheer size of this cooler. It is designed for a 120mm fan.
From the top of the cooler, we can see the six (twelve double sided) U shaped heat pipes which take heat away from the base attached to the CPU. They run the entire way through the cooler to provide maximum heat dissipation.
In the picture below, you can see the accessories that come with the cooler in that white box described earlier. It contains the LGA775 bracket and back plate, an AM2 bracket, the two types of screws to mount the cooler to the motherboard. A big “Thermalright, The Ultimate Cooling Solution” sticker for those amongst us who like our stickers, some thermal paste, two anti vibration strips to stick under your fan which is supposed to make it quieter and last of all; two clips to hold a 120mm fan in place.
Here’s a picture of the kit overall:
Well, that is enough about the kit itself, let’s move on to installation!
Installation
In order to install this CPU cooler, you have to take your motherboard out of your case. It requires you to fit a back-plate on the motherboard to support its weight. Most Intel coolers come with a pushpin design, however due to the weight of this cooler (790g) Thermalright have had to use the bolt-thru alternative. This is fantastic as it does not exert as much pressure on four small points on the motherboard; instead it is spread out over a much larger area on the back of the board.
The CPU back-plate
(Need to wait until Crimbo for this!)
The cooler attached to the motherboard
Complete installation
From our experience, it is recommended that you leave installing the fan until last as you will not be able to get to the screws to fasten it to the motherboard. One important thing to remember is; tight is tight! You do not want to put too much pressure on your motherboard and/or CPU!
Results
For the tests conducted – here is our hardware we used during the test:
Intel E2140 1.6GHz 800FSB 1MB cache @3.2GHz with 1.4375v
MSI P35 Neo2-FR
GeIL Black Dragon 2x2GB PC2-6400 C5 RAM @Stock clocks
Gainward 9600GT 512MB 650MHz Core/1625Mhz Shader/900Mhz Memory @750MHz Core/1875MHz Shader/ 950Mhz Memory
Antec Nine Hundred with all fans on LOW
Thermal compound used: Arctic Silver 5
For the temperature tests, we let the computer fully boot up and then waited 10 minutes to get an optimum idle temperature. To find out the maximum temperature of the CPU we ran Orthos Stress Prime95 for 30 minutes, it might get 1°C hotter if we left it on for hours, but we didn’t see much point in doing that.
This is about all I can do until Christmas guys; it was bought earlier than expected due to it having a huge £12 taken off the price for a one week only deal at OcUK, unfortunately I now have to wait four weeks before I get to use this beauty :(
Please can you let me know what you think, I am currently trying out for a reviewing spot with another site, although as always when complete I would love to reapply yet again for a job with OC3D, hopefully this might be the sweet spot they're looking for! :D
not bad,
too much "we" use though, started grating early on and then continued. otherwise pretty good mate, got the standards of the format and what needs to be done down nicely :)
You will get roughly 5C better temps if you're lucky. The one in copper is a LIMITED EDITION, they only produced 3000 in the world. Apart from the fact it weights in at 1.7KG which is a LOT of stress on your motherboard, it's not worth it ;)
Thanks for the comments so far lads, let's see what OC3D makes of this when I'm done ;)
one question: did you check the bottom of the TRUE to see how flat it is?
thermalright is known for not having a completly flat bottom. This because they first make the bottom flat and then solder the heatpipes onto it. and this may cause the bottom to have a bump :D
if it's not flat, you could lap it (do they say it like that in english? :P)
for the rest: i still would like to own one, this one or the black one, that's just a stunning beauty and the black one comes with two pair of fan clips.
They cool as the best
Thanks for the comments.
The curved bottom was in the earlier models. Today's ones are 100% flat and nothing to worry about.
You can still use two fans on this one, you only really need one clip to hold in a fan, they are very secure.
Only four more days until I can get some tests done with results! :)
sweet, i'll be looking forward to the results :D
Wich fans are you going to use, and in push/pull mode or both? :P
I'd like to see a Scythe ultra kaze 3000 in push + pull config. once :P
I am going to be using an Antec Tri Cool for now, when I get the chance I will try a push/pull config with two Antec Tri Cool fans.
A lot of the time most people get 2 - 3°C better temperatures, is it worth it? I'll leave that for you to decide ;)
Eventually I am going to hook up a Noctua Vortex to it, they're dead quiet and produce a lot of airflow. Maybe I'll write a review on it too, if you're after one ;)
The 2 - 3° C difference may be big when overclocking :)
I wonder wat would happen if you aim an airconditioning unit at it :P
And that Noctua Vortex looks interesting :D (as are the Tricool fans, good cfm/noise ratio)
Look who it is! Welcome to the forum mate! :D
Yeah I see your point there. I need to get around £60 from somewhere, my friend has a Q6700 for sale! He wants £80 for it, I'm really in need of some cash now LOL dad can't assist me though, he's buggered up the banking this month, maybe I'll have to miss it :(
I will do the tests on my dual core for now, when I get my Quad I will do the tests on there again and I will update it with the two.
Looks very nice and good review. I currently use a Rosewil 93MM ZX and love it but am looking to get something better and hopefully move some more air.
Anyone think this would be a big enough upgrade over it or keep what I have got?
Tony, haven't seen you in a long time mate, how are you?
I agree with you, it presents both the types of CPUs which are mostly used in the computing world at the moment, although it isn't a high powered dual core, it still gives you the general idea ;)
I am going to update it with both when I get a Quad so that we can see what this cooler is capable of.
Dark, what are your specs buddy? Why do you want to upgrade if it doesn't get hot at the moment? Or does it?
I use a E8400@3.6ghz at the moment but when i start pushing 4.0ghz or more I start pushing 57+C on full load and would like to cool that down a little so that maybe i can push the overclock even more.
