Ressurection of idea: Small case, full atx, watercoolable
mrapoc
I want a case I can put on my desk, quite small, easily carried etc.
It also needs to be fully atx compatible and watercoolable (aim to get TTL to cut/fit rad if hes willing :P)
There are a few lian li cases suitable but just wondering what your thoughts are. Possibly only needing a 240mm or maybe a 360mm. Aim to have the gpu and cpu in the loop mainly.
I already have a ddc ultra with alphacool top so that will need a place to go
cheers
well its definitely been done before but an A05 is pretty much THE case for it.... can't really think of many other 'small' watercoolable ATX cases, especially not with that much room to cram rads into!
pc7 / pc8 is a good starting point mate, normal atx layout and will fit a rad if you get creative.
Easy one for £100 is the A17 though, that will fit a thermo 120.3 in the front
