AngryGoldfish
Old N Gold
I'm going to be replacing my almost four-year-old Fractal system with something a little more high-end (at least in terms of chassis), and I have a question. I'll still be focusing on silence without liquid, but this time I want a more compact case, one that still allows for neat cable management, HDDs, and full ATX motherboards. Sadly, there are only a few on the market that cover that niche. The one I've always intended on building in is the Jonsbo W2. I love the little guy. And the other one is the Case Labs BH8. Until it was released, nothing from them fit my needs.
The W2 could be a great 'silent' case because it's so closed up. Solid aluminium panels and thick tempered glass should help reduce noise. But temperatures will no doubt be higher due to this, and considering I'll be buying Vega I need as much airflow as possible. The BH8 fits that criteria by offering more fan mounting position and open ventilation—plus if I ever wanted to add an AIO or go fully liquid, the case does support radiators well (I mocked up a quick soft tubing idea using a 5.25" bay reservoir/pump combo. But this could compromise noise dampening. So my question is:
Sacrifice on cooling and upgrade-ability with the closed W2 - it's sexy, more affordable, smaller (it will fit on my desk while the BH8 will struggle), and possibly quieter
vs
Sacrifice on silence and cost with the open BH8 - it's sexy, more water cooling friendly, offers superior airflow (fan speeds could theoretically be reduced), and is built to the highest standards
vs
