Requesting some assistance with a new build / liquid cool set up
Its all about air flow dude, if the rad fans are exhausting the air then its still a good idea to get air into the case to feed it. TBH its all about working with the airflow in your case and how you have it set up.
red yate loons here for pretty cheap!
http://www.specialtech.co.uk/spshop/customer/product.php?productid=6824&cat=886&page=2
Dimensions: 120x120x25mm
Nominal voltage: 12V
Nominal speed: 1350 rpm
Airflow: 46 CFM
Power consumption: 3,6W
Noise level: 23 dB(A)
With 3-pin plug, approx. 60cm cable and rpm signal
but i have bought some ac ryans for less than £4 each!! their on offer save 43%off :o
http://www.specialtech.co.uk/spshop/customer/product.php?productid=4349&cat=886&page=1
or with blue led's
http://www.specialtech.co.uk/spshop/customer/product.php?productid=6071&cat=886&page=1
ok getting back on topic. I ordered all of my parts last week and the last of them come in today. I actually live in the US, but here's all of the parts I purchased.
Silverstone TJ07 case
MSI 790FX-GD70 motherboard
Phenom II 955 cpu
enzotech luna rev a cpu block
4gb ddr3 1600 corsair dominator ram
dominator ram fan cooler
2 1gb 4890's for crossfire
2 ek 4890 gpu water blocks, nickel plated ones.
2 MCP 355 pumps
XSPC dual bay res (the one that holds both pumps)
MCR320 rad
MCR220 rad
100% enzotech compression fittings :D
Danger Den CrossSLI Fittings/Spacers
2 ball valves for drains.
PrimoFlex Pro LRT UV Blue tubing
PrimoFlex Pro LRT UV Green tubing
cooler master 120mm 1200rpm 44cfm 19db fans. (ordered the fans with a different case in mind, the fans on the tj07 are actually about the same).
re using:
150gb Rapter hdd
1000w ultra x-3 psu
X-FI sound card
I think that covers all of it lol.. what do you guys think?
