Replace Cooler Master Atcs 840 Fans?
bwin
There is no budget but i was wondering if the stock fans in this case were efficient. Anyone tell me if i need to replace them and if so which kinds..... Sound doesn't matter. i just want maximum airflow
I have the ATCS 840. They are very good, you can of course replace them and chuck a triple rad, so 3x120mm fans in the roof. I have noticed that under a desk it is really quiet, but out in the open they seem to be a lot louder, also now the bearings are wearing in a bit, a little vibration niggles from time-to-time.
50/50 meaning decent airflow and noise
they are nither massive CFM fans nor are they high DB fans.
slipstreams are loud but u said noise does not matter to you and you want maximum airflow thats just what the slipstreams 1900rpm are lol
did you happen to put a fan on the bottom?
O but the front fan and the top fans are running at a slow RPM. Would a fan controller be able to increase the speed? Or is that as fast as it can go?
are all thr fans attached to 12v via a molex.
i baught a gan controller about 4 months ago and never looked back
then go for what u want mate.i would use noctua P12's (ALX is selling some) as they are quite yet still push decent air
