Reference over Non Reference
Wraith
Bettyswollocks
Hello again boys & girls, I thought I would try my best to clear up some confusion that appears to rear it's ugly head quite often, and just to set records straight when folks ask "Which GPU should I use" Or what's the difference between Reference & Non Reference cards. So here goes.
Reference Cards:
A "Reference" card is a graphics card which is pretty much as the chip provider (AMD or nVidia) intended it to be as "Stock", these are carbon copies of the engineering samples which comprise of a standard layout PCB, reference cards typically use blowers which are better suited to small form factor builds or being stacked in SLI setups because they exhuast heat directly out of the IO plate unlike non-reference open fan style coolers.
Non Reference Cards:
A "Non Reference" card is a graphics card that has undergone some significant changes by a 3rd party i.e MSI, ASUS, Gigabyte, Sapphire ect. They do this to improve upon the stock cards including Memory frequencies, Core clocks, VRam quantity, power consumption and cooling solutions.
When it comes to "which GPU should I use" we have the usual responses of "what are you going to use it for", or "which PSU do you have", but I find the most common question is "Which GPU can I put in this case" and would it make a difference if I use a non reference card in a mATX or ITX build.
Reference cards are perfectly suited for smaller enclosed builds as they direct heat straight out the rear of the card at the PCI bracket end but they do tend to run a little warmer than the non reference cooled cards.
On the other hand we have the non reference cards which have 3rd party modified cooling solutions attached, while they do a fantastic job of cooling the GPU and VRMs, there is a slight downside in that they exhaust all the heat away from the card in almost all directions into your case adding more heat to your system temperature, so a case with space and good airflow is essential.
I hope people find this helpful.
Props to JR23 for corrections.
~Wraithguard~​
Handy little article, I think it may have been more correct to say 'reference cards typically use blowers which are better suited to small form factor builds or being stacked in SLI setups because they exhuast heat directly out of the IO plate unlike non-reference open fan style coolers'. It kinda reads as if reference is being confused with blower atm. :)
JR
maybe you should add in a piece about how only certain non-reference models will get waterblocks developed where reference models of Mid-High end are guaranteed to have blocks developed by the likes of EKWB, XSPC etc
And if you plan to WC, Research block availability for the card if its reference or non-reference regardless.
While you raise a good point on water blocks, most people simply ask the question "is my card reference or non reference" and it's been answered in the OP.
Given the frequency new cards are released it might be an idea to do a separate thread and keep it up to date with a list of current cards and available water blocks.
Why does this thread exist?
Seriously???
(valid reasons only)........
Hypothetical question: Someone asks I'm building a system in a BitFenix Prodigy which card would work best? The Reference or the Windforce...?
Not everyone is a clued up as the rest of us, merely just helpful pointers that's why.
Well if a mod makes this a sticky they'll see my comment anyway haha.
Trying to maintain a list of available blocks would would be a nightmare. To many cards, to many manufacturers and stuff changing way to oftern lol
Seriously???
I'm assuming this thread is catered towards not only enthusiasts (who should know) but also casuals and newcomers to the world of modding and pc building who are lost when it comes to the amount of cards being released on the market (i blame nvidia on this one).
Nice informative article.
I'm a big EVGA fan and they seem to be the only company that goes opposite to what you've wrote!!! Their ACX cooler is crap!
EVGA is crap though. Even if I discount my personal experience with them they still don't make sense to me as a viable option. They often cost more than the equivilent MSI/Asus gpu. Watercooling wise they still seem to be king but that shouldn't be why they are so popular as not everyone watercools.
Their PSUs are great though.
They are the only people to make overclocked reference cards though, the reference superclocked 780's were a nice way of assuring you got a strong chip, I guess it sucks for those who bought the standard ones. Also their range of accessories is unrivalled, backplates and bridges etc. Just a shame they can't buy fans or make heatsinks for sh**.
JR
JR
Basically if they design it chances are it'll be crap. IF they get another company to do it or use an OEM it'll be decent. I think some other companies do OC'd reference cards as well (I know inno3D did for a while although they don't sell them overhere) although I'll be honest that my knowledge in Nvidia partners isn't that fantastic.
