Red fittings.
cerbrus2
Banned
Hi guys and gals. I was wondering if anybody knows a company that makes red fittings. I need 1/4 threads. not to botherd about the size of tubbing as I am changing all of that to black tubing at the same time.
Just cant seem to fined any at all.
Ah those bits power ones are LUSH. that is exactly what i was looking for
But it seams as if those where a limited time only product. I was thinking of getting the black bitpower fitting and getting them anodised. as it will only cost £5 for some small fittings.
I was hoping for some red anadised Units if you know of any at all sieb. But if not I will settle for the poly fittings.
Those are the only red fittings that I know of to be honest I found them earlier when I was looking at barbs for myself. I only looked in Specialtech's sale section and barbs for 1/2" od 3/4" id tubing so there might be some for other sizes but i'm not sure because I haven't looked.
Those are the only red fittings that I know of to be honest I found them earlier when I was looking at barbs for myself. I only looked in Specialtech's sale section and barbs for 1/2" id 3/4" od tubing so there might be some for other sizes but i'm not sure because I haven't looked.
Thats a shame. Im trying to hunt down some of these red bits power ones now.
problem with the bitspower ones just like the black bp fittings, if you just hand tighten everything its fine, but i like to use a set of mole grips just for that extra 1/4 turn just to be safe and the problem with that is the scratch real easy, so your left with unsightly exposed brass, I'd buy any cheap fitting and paint them tbh.
You get the colour you want and as long as you mask the inside and the g1/4 thread you can clear lacquer coat them so they wont scratch up so easily.
