roman_noodles
Just as the Title says, any recommended fan controllers?
My budget is around $50 and I want a single 5.25 inch bay fan controller. Also at least 4 channels (preferably 5-6 channels), and I want each channel to have at least a 10 watt power limit. (3-pin connections for fans)
Also note if I need any fan cable extensions as I will be using the Air 540 case
(I just need to know about the rear fan and if it will reach to the front of the case)
I was thinking of the Lamptron FC5 V2, since there is 30 watts per channel I can connect many fans in case I want to upgrade cases and get more fans. The only downside is I cant find it on Newegg.
