Rastalovich
I`m after some tips/ideas from the modding side of the community.
I want to make a kind of vent-hood that will run from the side of a 120mm fan of a cpu cooler (or the side of a cooler around 120mm - eg a Ninja) and funnel to an outlet where a rear 80mm fan is usually housed on a case.
Now underneath this on a few mobos is a hs for pwm, to which I have some that may house a fan. So I guess I`m looking for suggestions of something to mold-into a rear vent hood.
I`ve got some of that vent coil tubing stuff, that u would get in an air-cooling-kit, but to directly implement one of these - first of all the cpu fan and the rear of the case are too close together to be able to directly implement it, particularly with the 80mm connectors and converters.
I`d like the whole of the exhaust from the cpu cooler to be thrown out the rear and not half-hitting the flatness of the rear of the case, i.e. missing the hole.
Looks aren`t too important. Chances are I`ll go to the extent of cutting some plastic icecream pot tubs down (like old style margarine tubs fromthe 70/80s for any1 in the uk) and using a tape to hold it together. The tape being either all black or silver.
C`mon modders
C`mon modders
