Realtemp Or Coretemp ?
Dicehunter
Resident Newb
Which one is more accurate, "Realtemp Ti" which is the latest over at extremesystems shows 2'c less that Coretemp, Or Coretemp ?
Which is correct ?
have pretty much for the last 3-4 years used coretemp started using it as a widget on win 7 but now use the full version. I've found it to be pretty reliable. Use hardware monitor as well, and its good but I like the tray icon that coretemp give me lol.
Personally prefer Open Hardware Monitor with the +15C threshold to get the correct AMD CPU temp, also use custom rainmeter skin for my display outputs.
