SwaleSmith
can anyone clarify if this board is E-ATX OR ATX seems that on he OC3D Review that it is E-ATX but on many other websites it is not can anyone clarify for certain???
name='zak4994' said:ATX Form Factor
One inch greater than standard ATX form factor 12 inch x 10.6 inch (30.5 cm x 26.9 cm).
lol.
Skeleton only takes a standard ATX, if you don't know already.
Chances are that it won't fit as the Skeleton is pretty tightly fit.
name='SwaleSmith' said:Is it widh wise as in from the backplate to the atx power cable or the other way...or both???
name='Ham' said:yep, width is right.
name='Ham' said:For the love of god, just dont get that case. If you want an open one get the Dimas table.
name='SwaleSmith' said:its a little too extreme for me, would also consider the danger den torture rack but can't fin anyone who has stock in uk
name='zak4994' said:lol eBay?
Amazon?
name='zak4994' said:BTW you also said that Antec Skeleton is just one choice for a case.
Any other cases in mind?
Gah! Gotta get some sleep.
It will sure as hell fit that larger ATX motherboardname='zak4994' said:Or you can get that new HAF tower thingy that was reviewed recently.
