Hey guys,
I am sketching out a rig I will be building around June-July or after Christmas this year, and I need some advice regarding the water cooling I want to be doing on it. This is the first full build I will have done, and also my first water cooled build.
I am building in a HAF-X with a P8Z77-V and a 3570k. GPU is going to be a VAPOR-X 7950, no water cooling for that.
I have decided on a Swiftech Apogee HD for the waterblock and I need advice on a 360mm length radiator, a pump, and a reservoir for the single CPU loop. I'd like some future expandability to be able to include water cooled SLI/CF GPUs, and another 360 or 240mm length rad in the front of the case (Will probably get rid of some of the 3.5 inch bays), preferably on the same loop.
Shipping to the UK and price under 150 GBP for the loop parts (excluding the Apogee HD)
Thanks in advance
Thanks in advance
