Radiator compatibility in phanteks enthoo pro
kramal
Hey there
In the front of the phanteks enthoo pro a 240 mm rad is supported, but what about two 120mm? Could that happen?
thanks
I'm not sure why you would want to do this other than 2 AIO's, but yes, if you have the radiators configured in such a way that they are on the left or right and not straight up. That was badly explained but if you look for toms latest dual xeon build, you'll see that he has 2 H75's in the roof of his 760t (I can't remember the case, sorry)
If someone else could find it and link it for you that would be great but I'm too tired tonight.
I'll find it myself, thank you! It's because im thinking about a project with two 770 watercooled with a kraken g10 and a 120 mm rad each. Think it could look amazing
I found it, it looks like a 900D and it supports up to 420 ( 3*140mm). that worries me a bit. But i think ill start out with buying a g10 for my 770 now and look if there is room for another, in case no one on here has the answer
In the roof you can have a 120/ 240/ 360 / 420 @ 45mm thick as most with a single set of fans.
in the front you can fit a monsta 240 if you remove all the HDD cages, both in front and bottom. 280mm monsta rad in the bottom is also supported ( 80mm P&P )
so technically you could fit a 240 AIO in the roof and a 280 AIO in the bottom and still have some HDD space.
Yeah the thing is i already have my 240 h100i in the top and im looking to watercool the 770 sli configuration with two seperate AIO coolers and kraken g10 and i dont want to remove the psu cover, since im thinking about some modding on it.
Sure it could work, you'll need to get a cooler for your CPU as well tho.
