OS: Windows Vista (64-bit)
CPU: AMD Phenom 9950 Quad-Core 2.6 Ghz
Graphics Card: Powercolor Radeon 4870 x2
Motherboard: M3A-H/HDMI
Power Supply: PC Power & Cooling S75CF 750W
RAM: G.SKILL 2GB x 2
Ok, I've had this successfully running for about a month and a half but today I started it up and it had trouble, starting up for a short bit then turning off repeatedly. I figured that out, I took out the CMOS battery and put it back, and it started up just fine. Then it comes to the login screen and everything is blue/green, there being no red channel. I switched out DVI cables, reinstalled the latest drivers, and messed around with the settings but nothing fixed it. I did find that at high resolutions on the desktop, I'd get pale red artifacts anywhere there was supposed to be red. And when I opened up WoW and reset the graphical settings (didn't matter what, so long as WoW had to reload the interface) it worked just fine.
So I reinstalled Windows, the installer wasn't missing the red channel and I got a fresh copy of Windows, everything seemingly working. So I install the latest drivers again, and this happens... again. Arg! What am I doing wrong?
