R9 290+4670k/3570k?
MrPetya19
Hi
Do you think that a Phobya 240 G-Changer (60mm) is enough for a R9 290 and a 3570k or 4670k?
If temps reach the 60s or 70s that's not a problem in my opinion.
This setup will go into a Prodigy.
Will they be running at stock or overclocked? I'd say usually the minimum for a CPU and GPU loop would regularly be 360mm, but as you have space constraints, and you're happy with 60-70°C, then I'd imagine 240mm will be fine, you might need to turn the fans up a bit though.
If you wanted more cooling so you could turn those fans right down, I know that you could fit a Alphacool Monsta 240mm rad in the top of a Prodigy but if you wanted you could get a 200mm Phobya rad or a slim 240mm, something like a 30mm would fit with fans. And there you have effectivly a quad in a m-ITX build!
Something like this with a 200mm in the front if you have the budget:
Hope I helped.
