There are very simular gasses R402a boils at -49.someat and R507 boils at -46.someat with r402a you need to add a desuperheat coil to remove some of the heat before it goes into the condenser with r507 you don't
R402a runs a little higher in pressure but you can back the charge off slightly as R402a has good heat carrying capacity.
In the end I think it is down to the individual if you neeeed the extra few degrees go 402a if you dont r507 in the world or overclocking I don't see your results would improve majorly between the two
