At this moment I'm running dual GTX 560 TI @ SLI with a HDMI cable from each one of them to my dual monitors.
Now I started thinking about buying myself an inno3D GTX 960 iChill.
At first I thought it might be best for dual monitors to leave the other 560 Ti plugged in and use the GTX 960 for gaming.
I also heard that the 960 would be enough for running dual monitors, but would it be enough to have a 1080p film running from VLC while playing for example CS:GO on the other screen.
Or would it be best to try and fit the both GPUs in?
My PSU's 850 watt so it's definitely enough for running five 960's if I wanted to
