Tried some searches gang and couldn't find much, so I appolige is already asked and answered...
When mounting a rad in the roof, you obviously set it up to push/pull and exhaust out the case.
When mounting a rad in the front or bottom of your case, I am not sure what the concensous is on the proper setup. Do you "pull" air in from the front/bottom and exhaust into the case? Or exhaust out the front and bottom?
I would assume they exhaust into the case, which then gets pulled out the top rad and/or rear fan.
Thanks for any info.
Whaler
Whaler
