question??? bout sli n dd w/bs?
PHILIP1193
will the low profile dd maze 4 blocks fit on the dfi board? as i may get another ultra extreme to add to phils system im buying (yes i know th current one is chrome but ill just keep that or put it on another card)
Phil
I would have thought it would have however don't quote me on that ;) Doesn't phils system just use one 120mm rad? might be a bit too much for two ultras and the cpu??
yea it does but i may swap phils bits out of his system into my v1000 which has two 120.1's in it if i fit phils so that should b fine then i hope.
And then run phils case with some more w/cin of another system, not sure yet but we'll see doing my home work so to speak
Phil
