Tbh only by seeing how much cheaper Q6600 is, and seeing that its got 2MB more chache as well as higher multi 9 instead of 7.5, id go for Q6600. Overclocks of Q9300 arent that great, because of the multi and a need of high end motherboard. Now if you asked Q9450 or Q6600 then and only then it would be a question of life
Not so sure the 6700 is as readily available anymore.
I would also assume with my questioning that Q9xxxx would include the Q9450. The whole thing really is Q6600 ~£100-£120, £70++ more for a newer gen. To what end performance wize ?
If u don`t care about watt usage, the Q6600 is viable.
Yup... I was gonna try and get it out in the States last week but as the etailers wouldn't deliver to a hotel it kinda limited my choices. Frys didn't stock it and even if they did, the price wouldn't have been that much better than over here online.
Definately go for the Q6600, for a several obvious reasons
1) Higher multiplier
2) bigger cache
3) because of the higher multiplier u wont be hitting a wall that fast if u got
high OC expectations.
4). Cheaper? well at least here in the Netherlands they are 30-40 euros cheaper...
the only advantage what I can think of the Q9300 over the Q6600 is the fact the is 45nm and thus runs cooler, but nothing that a proper cooling cant do so go for the Q6600!
Booted in at 4GHz, but was a mile away from stable.
Stable at 3.6GHz but my ram wont run at its stock speeds with the CPU at that frequency. Having to bring them down to 1066 to get it Prime stable. Also eating up quite a bit of voltage to hold it there.
Anyway... My point is that even with possibly one of the cackest VID's the chip is still pretty damn good. Get lucky enough to get a lower one and you should be able to clock high to the sky without too much voltage.
