Hi all,
First post here and i haven't had a real look around yet but i will straight after this post.
Ok, my problem is that i have a XSPC 240 rad that is only cooling a Q6600 @ 3.54.
My P95 temps run upto 70c. I have tried 2 scythe 107cfm fans in both push and pull and i get the same temps.
I tried 2 crappy thermaltake fans and i still get the same temps. So at the moment i have the 2 scythe in push on top of the rad and the 2 thermaltake in pull on the bottom of it. Still the temps are the same.
I have felt the tube and it's warm comming out of the rad which is weird as my loop goes 700lph pump - rad - swiftech Apogee Gt - pump.
If i turn my scythe's down to 1500rpm instead of 1900 the temps still stay the same aswell.
I really am at a loss as to what the problem is so any help or advice is sooooo greatly welcome
Thanks all
Nathan
*Edit*
Before now i had a crappy tai-chi case with the stock liquid cooling and i got the same temps but with the cpu at 3.4 and .5Vcore less
I really thought the new rad and fans would make a difference.
Oh and my liquid is
5% antifreeze (Ethylene glycol)
95% distilled water
A few drops on non-alcoholic Iodine.
Thanks all
Nathan
*Edit*
Oh and my liquid is
95% distilled water
