Q-tec 550wp gold 2 fans 80mm any good.?
atarist
Hi,
i.v just got a Q-tec 550wp gold plated p.s.u. with 2/80mm fans 30a
Taken out ov a old p.c. which had a shot Mobo with a shot cap,
and iv just put it in 2 my internet p.c. spec is,
psu/celerron-D 3Gig soc 478 256c 553fsb
ram/ 1x3200 512 / 1x2700 512 ddr
hd/ seagate ide 20 gig ata100
dvd/ 2xburners
agp/ gigabite 6800gt 256ram
the thing is i hear that people saying on the net that Q-tec are a Bad p.s.u.
and cant put out 550watts at full load just 400watts max.?
are Q-tec that bad.?
am i takeing a risk by useing the p.s.u. in my p.c. spec.
I aint useing the rig for any games just for the net.
has any one on hear had a Q-tec p.s.u. go Bang on them befor.?
Take it out and bin it. It wouldn't surprise me if the Q-Tec killed the motherboard in the previous system.
For £30-35 you can get a PSU that will run that system no problems and now put you in danger of a totally fried system...or worse.
noooo not qtec i thought they died
bin it before it breaks your HOUSE!
those things are DEADLY!!!
get rid at once!
you are taking a MAJOR risk by using that psu for any length of time
Dam are there that bad Q-tec is now out old p.s.u. back in thanxs for the info you 2.
there are noisy p.s.u.s Q-tec ones.
name='Jim' said:
Here's my input: Coolermaster 460w eXtreme.
It may be a little bit lower on the old wattage numbers than some of the other mentioned units, but I bet you it delivers more stable power.
True that, having the watts high doesn't mean much really, as long as it's a constant flow across the rails.
Stable > all :D.
i ran a q-tec 450w ones some time back with a 2.6Gig p4 for a year and,
I all ways thought that Q-tec where a good make till i googled q-tec n,
See the Bad right up on them,
Thanxs for all your info on this people.:)
I all ways think its best 2 get a secand opinion from people in the end :)
