Hello, i am building myself a cheapish watercooling setup (budget £80
, not wanting to use a kit)
I have so far chosen the following components:
Alphacool NexXxos HP Pro (very cheap from specialtech)
1/2" Barbs Throuought
7/16 UV orange XSPC tubing
240mm Rad, probably xspc
I am not sure on the Pump that would be suit my needs.
I am currently considering these options:
XSPC single bay (5.25") reservior/pump combo unit
D-TEK DB-1 (i would probably add a swiftec micro-res)
Which would be reccomended?
I am in a small case (pc-a05 by lian li) and so i want to reduce the loop as far as possible. I am also looking at adding a gpu and maybe chipset to the loop at a later date.
If you guys have any comments on my components/reccomendations they'd be very welcome.
