You are using an out of date browser. It  may not display this or other websites correctly.
You should upgrade or use an
alternative browser.
They are the same pump, the Danger Den one just has a different top.
It is a good pump though more than enough for most setups.
					Derp, I just realized they are both labeled as Danger Den. *must not just look at pictures*
Those pumps are also sold as Swiftech or just plain Laing DDC's as well but they are still the same pump.
I noticed one is version 3.2 and the other 3.25 but looking at the specs I can't see any difference. This is the version you wwant though.
http://www.frozencpu.com/products/5..._MCP355_12v_Water_Pump_Native_38_120_GPH.html
