grandpatzer
So my impression is that for rads you either are supposed to push or push pull.
Because the screws need washers I ended up installin 2 120mm fans with 4 fan screws to case, the 4 M3 screws to rad and it is pushin air up(pull).
in IDLE the fan speed is 640rpm, LOAD it is 750rpm.
My 965 be 1.45v 200x19 gets to 57c after 11 intel burn test runs and it even might go higher.
This is similar to my Mugen 2 push pull, so it is equal to high end push pull air so I still think it's OK.
