Bezzaboy123
Hi guys,
So got a new case for my small HTPC build, Its running this spec below:
[font=Verdana, sans-serif, FreeSans]AMD Athlon II X3 460 (underclocked to 3GHZ)[/font]
[font=Verdana, sans-serif, FreeSans]Asus M4N68T V2 M-ATX[/font]
[font=Verdana, sans-serif, FreeSans]4GB DDR3 1600MHZ G.Skill RAM [/font]
[font=Verdana, sans-serif, FreeSans]1 x 128GB Crucial SSD[/font]
[font=Verdana, sans-serif, FreeSans]2 x 2TB WD Green's[/font]
[font=Verdana, sans-serif, FreeSans]My problem is the PSU that came with the case is this:[/font]
http://www.envizage.com/products/psucit300micro-cit-300w-micro-atx-psu-power-supply.html
its M-ATX which is making it really hard to find replacements, I have had suggestions given to me but a 300/450W M-ATX psu costs more than most 5/600 watt modular ATX power supplies, I know that PSU's are important but seeing as this is just a build of recycled parts its not that imperitive I pick a decent branded PSU, this 300W is fine for what it is,
But it is so damn loud!,
My question is, would it not be better just to replace the fan? is it the PSU that is causing the fan to spin at such high RPM? if I remove the Hard drives nothing changes and if I put the PC under load the fan still spins at the same speed which leads me to believe It wouldn't be such a bad idea putting a 80mm noctua or the likes in it and controlling the fan with the onboard fan headers?
What are you're thoughts people?
thanks!
thanks!
