Feronix
Hey guys,
As I'm looking to start a new build, I also need a new PSU to go with it. The system will eventually have an i7 3770k, 2x GTX670, 16Gb 2133 RAM, and maybe 2-3 mechanical HDD's and 2 SSD's
At first I was looking at Corsair PSU's as they're supposed to be the very best. I soon figured out that for the price of a Corsair 750 Watt Gold PSU, I could also get a Cooler Master Silent Pro M2 1000 Watt Silver PSU. So I was going for the CM one.
Then, I realised that I would never need 1000 Watt with a system like that, so I went back to look at the Corsair ones and found the AX750 and AX850 to be somewhat close to the price of the CM Silent Pro M2 (the AX850 costing €20,- more).
I'm going for an all black build and i want to use individually sleeved cables. I was looking at the Bitfenix extensions but for these Corsair PSU's there appear to be all ready kits which would eventually cost me about the same, though I'm not sure on the quality.
What do you guys think? Corsair over CM or are both good brands? If Corsair, would 750 Watt be enough or should I go with the AX850 just to be on the safe side?
Thanks in advance!
Thanks in advance!
