Hey guys
I want to braid my psu cables and some case cables but I have a few questions.
First off is will my psu have enough power for my future plans. I know it works fine with my current setup but I want to watercool down the line as well so I want to know will it be enough for all that or will I be pushing it that tad bit too far.
Right next up is does anyone know where you can get another set of cables for the new generation Corsair AX series psu's? I want to have a second set spare in case I need to send it back to the factory.
Next question is what tools are best for cable sleeving. I tried looking on mdpc-x's website but cant access it until tomorrow evening.
What braid and sizes would I need?
Last thing is I would like your opinion on colours. I was thinking of going just black and white and then doing the same with the watercooling but the only thing that is kinda nagging me is the light green heatsinks on the Sabertooth motherboard. So I was also thinking maybe going black with some small light green colour thrown in to boot. Only issue with that is trying to find a green coolant to match when I watercool.
Anyways any help and opinions would be appreciated.
Thanks
Thanks
