Project Unnamed
cybermaniac
Project Allspark
Project Allspark
Case:
A+Case Blockbuster Storm (22cm Fan) MicroATX
http://www.kustompcs.co.uk/acatalog/info_1403.html
or
EV Black/Silver MATX Cube Case with Acrylic Side/Top Windows - No PSU - 12cm Blue LED Fan
http://www.ebuyer.com/product/135582
Optical Drive:
LG GH22NS40 22X SATA DVD±RW/DL/RAM Black Bare Drive - OEM - thx charlie-j
http://www.ebuyer.com/product/151999/
HDD:
Western Digital WD2500AAKS Caviar SE 250GB 7200RPM SATAII/300 16MB Cache - OEM
http://www.ebuyer.com/product/124733
PSU:
OCZ 500W Mod XStream Pro PSU - 2x PCI-E 6x SATA
http://www.ebuyer.com/product/152009
Grfx Card:
ASUS HD 4870 512MB GDDR5 Dual DVI HDCP HDTV out PCI-E Graphics Card
http://www.ebuyer.com/product/152939
Mobo:
ASUS P5E-VM HDMI iG35 Socket 775 onboard VGA 8 channel audio mATX Motherboard
http://www.ebuyer.com/product/142654
Ram:
Crucial 2GB kit (2x1GB) DDR2 800MHz/PC2-6400 Ballistix Memory Non-ECC Unbuffered CL4 Lifetime Warranty
http://www.ebuyer.com/product/119279
CPU:
Intel Core 2 Duo E8400 Socket 775 (3.0GHz) 1333FSB 6MB L2 Cache Retail Boxed Processor
http://www.ebuyer.com/product/139971
General Gist:
Mini-ATX Case
4gb Ram
Intel E8400 @ 4ghz air cooled
ATI 4870
Asus mini-atx mobo
~500w modular psu
Vista Business x64
this will be designed as a portable solution for a LAN gaming pc. something that will offset my previous project (project leviathan) due to the fact that that beast is HEAVY. - Also there is always a risk when moving water cooled rigs, especially one as heavy as leviathan.
What I shall also be doing, if I go for the cheaper case, I shall be modding handles into it and maybe a 120mm on the top.
Initial views and ideas before I post full details are more than welcome.
name='zak4994' said:
I wonder if a 4870 will fit in that case...
aye it should. On the smaller version of that case, someone managed to not only get a 4870 in there but also a scythe small form cooler for q6600 cpu
however.........VEEEEEEEEEERY tight squeeze - hence why im opting for a modular PSU otherwise i've got a sneaky feeling it aint gonna fit :P
and no socks....im NOT going to dremel my cables :P
edit:
also - if you guys can come up with a kickass name, that would be awesome too.
I used to have that case and I can fit a 8800GTX so I think it should be fine for the 4870. Hope to see how you getting on.
name='kataras' said:
Get this motherboard instead and you can proudly call your rig Lanparty! :p
Jeez. A great cpu in there, not necessarily overly overclocked so u can use a decent smaller cooler, 4g, one of the top gfx cards that doesn't get too hot, some small optical - like a laptop one, couple of drives, 400-500w psu, good air flow, stick a good wifi card in there -- and u have one heck of a performance gaming... well do anything I guess, pc.
Package all this into a similar size to a console, good enough to look stylish in a tv room and u have a massive seller. Be sensible with the price.
name='Kerotan' said:
Crucial Ballistix for £25... wish needed some DDR2 lol.
On topic I think this should be a really interesting build and if you're into the Transformers film, you could call your project All Spark
http://en.wikipedia.org/wiki/Allspark#2007_Transformers_movie
:D
GENIUS!
and thx for the comments peeps - i'll deffo be checking out the dvd drive too!
now....just for the cash :D
I've decided on going for a 4850 due to the fact it will only be used as a LAN pc and not as a main gaming rig. no point spending the extra £50 on it.
