Hey everyone! First time building a rig with intentions of overclocking and I'm going to need some help (but that's for another forum). I'm moving from an older gaming/school PC to a much newer and nicer setup as follows:
Intel I7-4770k 3.5GHz (which I'll certainly be bumping up)
Corsair H100i Sealed loop CPU cooler
Asus Maximus VI Formula ATX LGA1150 Motherboard
G.Skill Trident X Series 16GB (2 x 8GB) DDR3-2400 Memory
Samsung 840 Pro Series 256GB 2.5" Solid State Disk (boot drive as well as UE4/UDK/Visual studio etc.)
Western Digital Black 2TB HDD
EVGA GeForce GTX 780 Ti 3GB Superclocked ACX Video Card x2 (debating on this)
EVGA SuperNOVA 1000w Platinum 80+ PSU (fully modular)
Win 7 64 bit Ultimate SP1
Cooler Master Storm Stryker (White) ATX Full Tower Case
Leftover CD/DVD R/W drive (too lazy to glance over
PC part picker link for those interested.
>http://pcpartpicker.com/p/3CVEs<
_________________________________________
So tell me what you think of the proposed build! Any conflicts I may not have noticed? Do you like the color scheme? Am I going overkill with anything? Just kidding, there is no such thing as overkill
__________________________________________
Next a few question for you guys (and if I'm in the wrong place, please feel free to move my post or direct me where to take it!):
1) I noticed that while Intel has certified this particular Processor, Motherboard and RAM configuration on their website - other parts of their website say not to go over 1.5v with the Haswell processors? So should I drop to a 1600 speed set at 1.5v or is 2400 @ 1.65 "overclocked" (still new to this). Most importantly, will it be stable, cause damage or reduce the life of the processor.
2) It seems that the only difference between 780 ti's is how "overclocked" they come standard and the HSF/cooling block they come with. If I were to buy a base model 780 ti and overclock it, would I be achieving the same thing at a reduced cost? Or is the "superclocked" version actually worth it?
3) The 2TB HDD to be used in this build is fairly new (~less than 2 months old) and doesn't have much on it so far, save for some school work, the OS and questionably acquired music (shhhh...). Would it be damaging to the drive to just wipe it and start over, since removing windows files can be a real pain? And if it is possible to simply wipe it with minimal wear'n'tear, how would I go about doing that effectively (if there's a post about this already, please point me to it
Edit: 4) With the new Z97 boards just around the corner (May... 11th?) I'm planning to hold off on a MOBO purchase with price in mind. It's my understanding that the new Z97 chipset supports things I wont be using like "M.2" some new SSD interfacing method(?). And... well that's really all I know atm as details haven't yet been released on the boards but what are your thoughts? Will there be any advantage in terms of frame rates in engine/editor applications or would it be best to stick with a Z87 board when the new line launches reaping the reward of extra savings?
_______________
Thanks for your time everyone! I look forward to building this with you.
_______________
