Project Star Wars old republic! **Not 56k Friendly**
Prime 95 930 @ 4.4Ghz 1.36V 62 59 61 56 - 5x8 runs, Temps during games are 45max on the first core down to around 40 on others and GPU is around 43 Max, So yeh not bad, Fans are all on silent :] Rooms 20C.
Very happy with how it's turned out, Although it's a Absolute bastard to bleed it's taken 5 hours just to get the pump to be quite, Going for Cylinder next time.
looks very snazzy.
1million brownie points (worth 0.5 Imperial Credits) have been added to your inventory to be used at any merchant in the 'Elrood Star System'.
spend wisely
Rig is looking great Natasha! I love the color scheme.
[mod voice]shrink those pics though![/mod voice]
Hi,
Very nice work there and remarkably effective cooling considering the fairly modestly sized rads - though I do remember you saying they are paricularly good ones. A very neat build indeed
Scoob.
Temps have gone up by 3-4C now, The MX4 has hardened, Always does that after afew boots it's kinda annoying.
Gone UP? I thought many thermal pastes got better after a few power cycles? I guess MX4 works a little differently. AS5 seems to get a little better over time, though I used TX-3 last time and temps have been fairly stable.
3-4c, while a little annoying, isn't so bad though...besides, it's TJ07 time now right? So you can move on from this build
Scoob.
