The white is so clean made nicer with the red rad mount, kudos fella this is turning into a quality build.
great build buddy looks like its coming on a treat.
maybe on your mk2 model you could build the frame out of clear tubes and use it as a reservoir for the water cooling loop
Neat idea and great execution!
Now what it needs is a blow-off valve which triggers after dropping below high CPU load.![]()
Looks great fella, nice work and it's not often we see scratch builds to completion.
Gives me an idea for a future build though.. an ITX build in a modified windowed air box with a K&N as the intake filter using PPC fans. Mmm.
