This is a log about a project i have been thinking about since December 2011
I have always wanted to try a watercooling build and my sponsor at Phobya twisted my arm when he agreed to help out with a few small bits a pieces
Anyway, the original plan was to use the endless 690-2 Coolermaster Chassis i had around the place from previous builds
I also wanted to incorperate the Bitfenix Fans that i won (review is on here: http://forums.overclockers.co.uk/showthread.php?t=18301235&page=6) so i chose a 140mm size radiator - a Phobya G-changer 420mm rad
Anyway, i really wanted to do this properly as i have always had reservations about electronics and liquids and really did NOT want this to be an unplanned exploration
So since December ive been hoovering up all the credible information on the net and been in talks with a few people on the interwebs
I'd like to thank the people that helped me with this project - with advice, inspiration, etc: Cleeecooo, KiiYzOo and hughythomas
The first thing i would like to do is add a screenie of what i am *hoping* to achieve
Intro:
The Project started out as a Coolermaster 692 lite that i was going to use with an external radiator
I would dremel out the centre of the roof and sit the rad ontop
I mocked up the design in Autocad to work out dimesnsions etc.
A screenshot can be seen below:
Then, one day, someone offered me a TJ07 and 480mm rad for a minimal amount of money as they were in poor condition and would need alot of time and effort to restore them
So i thought to myself: "Why not?"
The 692 build would have look silly, and childish imho - the TJ07 has a real classy look and ive always wanted to try a Silverstone case as everyone always goes on about them
Anyway, i set about designing this new build on Google Sketchup as there is a repository of components online that are REALLY useful!
BTW, Google Sketchup has NOTHING on Autocad, not even Sketchup PRO
Naming:
With this build i want to build upon the black/blue theme that i was doing with my "Home" computer - so this will be black and blue too
A friend of mine, when asked for a naming suggestion for a black and blue build, said: "Project: Bruises"
But i thought that lacked a certain sofistication the TJ07 demanded so i chose: "Project: Indigo"
Whilst away from home (im only home for April), i was ordering and test fitting every item i thought i would require
So there are a jumble on images of me when i was doing testing with sleeving/paracord colours, flushing rads, takinig pics of fittings, etc
And after all the prep work, of which i have a two page word document laying it all out, i will get to the actual build pics
BTW, the stage i am at right now can be seen on the screenshhot below.
I will be adding photos as i go, i have ALOT to share with you guys
Intro:
Naming:
