Ok this is a little different to other projects where you normally know what the outcome is going to be because this time, I have no idea. This is due to the fact that from a bored time at work and sketching ideas for PC's on a sheet of A4 I came up with a water cooled PC. The only problem was that the case didn't exist, what to do, what to do??
Make it!!
This is a completely custom built case from the ground up. I have designed it fully at work now as a gaming server for the LAN events I goto and also for a show piece in my room aswell as an online game server from here.
The spec will be -
Barton 3000+
1Gb Corsair XMS TwinXPro PC4000
DFI LanParty Ultra2-B
MSI GeForce 5600XT
80Gb SATA Barracuda
DVD/CD-RW Combo
Asetek water cooling kit CPU, NB, and mayb GPU
This is likely to change many times throughout the project. Well first pics should be tommorow as long as I can get the chasis finished.
Until then, I'll leave you wondering.....
Cheers
Boardy
Make it!!
The spec will be -
Barton 3000+
MSI GeForce 5600XT
80Gb SATA Barracuda
DVD/CD-RW Combo
Cheers
Boardy
