So I'm getting a new gaming PC to replace my aging i7 920 which its on its last legs. Decided to give watercooling a try
My PC names are from Star Wars Star Destroyers, very nerdy i know
so my current system is called Executor, this one will be called Eclipse. It will be mostly used for flying in Microsoft Flight Simulator X as I am also building a home cockpit. Might give Skyrim a try too. I also have a triple Dell 24" setup which is really immersive!
My specs:
Case: Corsair Obsidian 900D
Motherboard: MAXIMUS VI EXTREME
CPU: i7 4770K
CPU Block: XSPC Raystorm Copper
Memory: 16GB (2x8GB) Corsair DDR3 Vengeance Pro Series Red
GPU: Sapphire 7970 OC
PSU: Corsair Digital AX1200i
Braided Cables: Corsair Individually Sleeved PSU DC Cable Kit,Type 3 (Gen 2) RED, Corsair Individually Sleeved AX(i)1200i/860i/760i ATX 24pin Cable (Gen 2), RED
SSD: 2x256GB Samsung 840 Pro
Lighting : 2xSharkoon 12" UV
Sound Card: Asus Xonar D2X
Radiators: XSPC AX480, XSPC AX360
Pump : Alphacool Laing VPP655 D5 Pump
Pump Top: EK D5 X-Top
Reservoir: EK-RES X3 250
Fittings: Koolance QD3 Quick Disconnect Compression
Tubing: HighFlex Hose Clear
GPU Block: EK-FC7970 - Acetal + Nickel CSQ
Coolant: Mayhems X1 UV Blood Red Coolant
Monitoring: Aqua Computer Aquaero 5 PRO LCD Fan-Controller
Temp sensor: Aqua temp inline sensor
Cooling Fans: 120mm Corsair Air Series SP120 High Performance Edition
Projector Eclipse 1 by GodAtum, on Flickr
Projector Eclipse 2 by GodAtum, on Flickr
Projector Eclipse 3 by GodAtum, on Flickr
Projector Eclipse 4 by GodAtum, on Flickr
Projector Eclipse 5 by GodAtum, on Flickr
Projector Eclipse 6 by GodAtum, on Flickr
Projector Eclipse 7 by GodAtum, on Flickr
Projector Eclipse 8 by GodAtum, on Flickr
Projector Eclipse 9 by GodAtum, on Flickr
Projector Eclipse 10 by GodAtum, on Flickr
photo by GodAtum, on Flickr
Idle is around 33 C.
In gaming the temps are around 35-45 C.
On 100% CPU load with Cinebench max temps are 54C. Fans are at 54%. I have no idea whether thats good or bad lol.
cinebench temps by GodAtum, on Flickr
Untitled by GodAtum, on Flickr
My specs:
CPU: i7 4770K
