Surfie
Its a really nice system, I like it.
I know I'm in no way qualified to criticize you, as I'm not watercooling myself at the moment, but what is looking a bit odd to me are those long hose-runs. I know that thats mostly because the case is so huge, but I think it might've looked slightly better, if the res was moved to the right, between the front rad and the rest of the system, where the huge clearing is at the moment
Following your thread now, btw.
I would probably also have turned the top rad around, so that the fittings are on the right and instead of going from the front rad to the cpu, I would've gone front rad -> top rad -> cpu -> gpu -> reservoir/pump -> front rad
But that is just my opinion, keep in mind that I have no experience with watercooling, I just think that it might look nice, optically![]()
Actually, that was my original plan. However there are restrictions in place. For one, placing the res/pump where you suggested means either having the whole thing supported by only one screw (scary) or mounting a new plate behind the optical bay to hang the res/pump from (something I have neither the tools nor the know how for).
As for the top rad, there is only one way to fit it without causing kinking or overly complicating the loop, and that is the way I've done it. Having the mounts on the other side would also require removal of the optical bay, which I need for the optical drive.
Yes I agree that the two long runs are sub optimal, but I really had no choice. The pump/res would only really fit where I put it.
Edit: you will understand better once I upload photos with the side panel on.
