name='Bungral' said:Did you go with the freezespray to get the heatsink assembly off or just pry it off?
name='Kerotan' said:This project is lookin well decent, those fans look the business! great job mate.
name='°TheMadDutchDude°' said:Very nice job so far buddy.
One thing, won't that SB cooler get in the way if you're going to have multiple graphics cards? In CrossFire or something like that or are you sticking with one card?
Nice work on the lapping.. I don't want to do that with my CPU LOL I don't want to break it! :worship:
name='zzhang' said:
name='rrjwilson' said:GPUs are always hotter than CPUs. Your system needs to be watercooled completely simply because the heat soak of the 4870x2 into the CPU loop will mean toasty temps.
name='GavX' said:I BELIEVE that is a common cause, the EK block uses metal washers around the MOSFET area, if you can use paper washers it should work fine, or something along those lines afaik. I think the idea is they become shorted and do not work.
Next to the LED there should be numbers (like 1601 on my 4870) can you tell us what light is lit up as that way you can hopefully know more whats going on
name='rrjwilson' said:That makes sense my GTX blocks have paper washers for that reason
