Project Blood Red (Corsair 600t)
Cloudie
Hello everybody! After seeing some fantastic work on various places, I thought I would start a project log of my own! This is the first time I'm attempting a Case mod and custom liquid cooling setup so this is an exciting journey for me! Right now everything is aircooled with a Corsair H100 so it was time for something different ;-)
To start with the hardware I have or plan to have setup in my build:
  • Intel i7 3770K
  • Asus Maximus V gene
  • Corsair Dominator Platinum 2x4GB 2400mHz CL10 (in order)
  • Sapphire HD 7970
  • Curcial M4 128 Gb
  • Samsung Spinpoint 1TB F3
  • Corsair AX750 PSU
  • Corsair 600t White
Liquid cooling equipment
  • EK Supremacy - Nickel Plexi CSQ
  • EK FC-7970 - Nickel CSQ
  • EK-MOSFET ASUS M5G - Acetal + Nickel
  • EK-RES X3 150 with EK-RES X3 - Multiport TOP and 40mm internal tube
  • Alphacool NexXxoS UT60 Full Copper 360mm
  • Alphacool NexXxoS ST30 Full Copper 360mm
  • Swifttech MCP35X Pump with
  • EK-DDC X-TOP CSQ - Plexi
  • Corsair Sleeved Modular Cables - AX850/AX750/AX650 - Red
  • EK-Ekoolant Blood RED premix
  • 9 x Corsair SP120 Quiet Edition
  • 1 x Corsair AF120 Quiet Edition
  • 2 x LED 5mm TWIN ULTRA WHITE (Reservoir and Pump top)
  • 1 x LED 3mm TWIN ULTRA WHITE (CPU block)
  • 2 x Feser Tube NON-UV - 3/8 ID - 1/2 OD - CLEAR / PURE
  • 2 x Alphacool 1/4G plexi fittings for 5mm LED
  • 1 x 10MM (3/8 ID - 1/2 OD) Bitspower fitting 45 Rotary - G1/4 Black Sparkle BP-BS45R2CPF-CC2
  • 5 x 10MM (3/8 ID - 1/2 OD) Bitspower fitting 90 Rotary - G1/4 Black Sparkle BP-BS90R2LCPF-CC2
  • 8 x 10MM (3/8 ID - 1/2 OD) Bitspower fitting - G1/4 Black Sparkle
  • 1 x Bitspower 2xG1/4" Fillport Black Sparkle BP-BSWP-C04
  • 1 x Bitspower Crystal Link Tube For 3-Slots (SLI/CF) BP-CLTAC-S3
  • 1 x Bitspower G1/4 Black Sparkle IG1/4 Extender 15mm BP-BSWP-C60
  • 1 x Bitspower G1/4 Black Sparkle Q-Rotarary Adapter
  • 3 x Bitspower G1/4 Black Sparkle Rotary 90 Degree ID 1/4 Adapter
  • 2 x Bitspower G1/4 Black Sparkle Stop Fitting
  • 1 x Bitspower G1/4 to G1/4 (2x OD) connector Black Sparkle
  • 2 x Bitspower Multi-Link (SLI/CF) Adapter Mini BP-BSWP-C48 Black Sparkle
  • 1 x Bitspower Valve Black Sparkle BP-MVV-BK
Alright so lets start off. I do appologice for the back camera quality as I can only work on the PC at night time. Ill make some high quality pictures during the day when I can.
The idea will be to have a clean as possible loop with as many straight lines as possible. In the future I might change the tubing to full Bitspower Crystal links for an amazing look.
Right so the loop will be the following: Reservoir - Pump - GPU - st30 rad - mobo -(crystal link)- cpu - ut60 - reservoir
Received the first package with some liquid cooling goodness and started right away!
I really liked the look of the GPU block and Backplate so I started by placing the GPU block and backplate on the PCB.
When I looked back it seems I used to much thermal paste so I cleaned it up again and redid the paste with a credit card.
Loving it!
Oke so now its time for the CPU and the Mosfet block
Cleaning the CPU
I applied the Gelid Thermal paste as a dot and placed the CPU block on top. This time used a lot less paste so I'm hoping its enough. If the CPU temps will be higher then I expect I'll redo this as well with a credit card.
Oke so because I want to place the UT60 rad in front in the same style as Orca I had to drill out the drive bays
Fitting the rad to get a visual image for the space
Next will be cutting out the top mesh to make room for the alphacool st30 360mm rad.
This pic shows the raw cut I made.. I've been filing off the raw edges and placed some rubber O rings where the rad with fans will be mounted. I'm still looking for a rubber U-ring shape strip to give it a clean finish.
I've also cut out the inner webbing of the top mesh to make room for the rad and give it a slight better airflow.
Test fitting with the UT60 as I didn't have the ST30 yet
At this point I wanted to see which fittings degree to order so I placed the most important parts back in the case. Its going to be mostly 90° fittings as the lines are pretty tight.
I'm going to dremel out the inside of one of the 120 fans that came with the case as a radstand so there is some room between the side and the mesh for better air intake.
New order arrived! Most important part will be the st30 rad.
After placing it in the top I found out that I cant close the mesh as I wanted because the length of the rad is to long to fit. I'm going to try and see if I can make it fit otherwise I'm going to put the fans in pull on top with the rad blow in the case. I do want it the other way around to see those nice red corsair circles inside instead of the rad. If anyone has any experience tips do let me know.
Ill make some pics in the new year to show where the problem might be.
Bit of a chaos but the result will be worth looking at ;-)
MATX board in an ATX case - just looks so wrong.......
I'd rather have an ASUS ROG Maximus V Extreme but as I've bought this board just when ivy bridge got released there wasn't much of a choice. ;-) This board preforms extremely well and in the end I'll never use more than two PCIe for crossfire. No need for an upgrade to a full ATX board ;-)
Looks great so far.
I thought there was something odd looking, I never realised it was mATX at first. My brain just assumed it would be ATX :lol:
Haha well I guess that's a good thing. With the side panel on you can't even notice the difference ;-) (Until I start with the side panel as well)
I just put a ATX board in a switch 810 does that look wrong?
That looks nice and tidy to me. (well at least it could be if you don't rush it)
No worries there. I'm not doing this to make it look messy in the end ;-)
Looks great so far , I'm loving the backplate on the GC.
Cheers mate! Yea even though I didn't like the EK CSQ in the beginning.. it is starting to grow on me. The icy plexi will look great with some LEDs and EK's Blood Red running through them.
Alright... ! I just ordered some Bitspower Black Sparkle fitting as I just love the finish!
I'm planning to use a Q fitting together with a Bitspower Valve right after the outlet of the pump for a draining system. The only downside will be the UT60 radiator as the in-outlet of the rad is facing up. I might use the bleeding port as well with a Q/L fitting + valve to drain it, but I'll have to wait and see how that ends up.
Once the order is in I'll start flushing the rads and hook everything up. I hope I'll end up with the st30 in push config, but otherwise settle for the rad in the case with the fans on top.
Thanks for the support so far!
Finally back with an update!
The Black Sparkle Fittings came in and I was eager to start working on the rig straight away. In the mean time I flushed out all the rads and secured the ST30 in the roof by sliding it in with the top hooked in already ;-) It sits there very tight and secure!
Also received the Monsta rad which I won in the TastyPC christmas compo (Cheers Lauren!) so I'm going for that in the front instead of the UT60 ;-)
So I started by hooking everything up for some leak testing... Don't look at how the fans are mounted in the front as that was just one huge brain fart :/
Soon enough I discovered some parts of the loop were leaking!! It was both the CPU block as one of the 90 degree fittings. I took out the CPU block and checked if it was assembled correctly.. took extra care but it ended up having the same result. I did notice that the outer O-ring was not a tight fit in the block. I don't know if that is normal or not but that might be the reason it leaks...
I did have a spare for the fitting but after a few hours with the pump off a drop appeared on another fitting where it can rotate..
I send my supplier a mail regarding the issues so I'm hoping for a quick response. Other than that I'm quiet happy how it's going to look ;-)
You've done a decent job with the 'loop' - If i can call it that considering all of the tubes seem to be perfectly straight :p
Points still stand about the mATX board in an ATX case. Just looks wrong.
