SaaintJimmy
Member
Hey everyone! Back at it again, this time with my big project for the year, which will be the main entry in CMWS20.
Project A.R.E.S. (acronym for Astral Robot Enclosure System) will be based on the Cooler Master C700M and, as the name suggests, it will be a project themed around SciFi design and space. In particular, my main inspiration will be Robot from Netflix's Lost in Space, from which I will take some elements and merge them into the build. It won't be some sort of Lost in Space themed mod, I will just take some inspiration and make my own thing out of it.
First of all, I would like to give a big shout out to my partners and sponsors, because without them nothing of all this would be possible:
HWLegend Modding - Trippodo - Cooler Master - INNO3D - Asrock - XPG ADATA - Bitspower
Now let's go through some pics of the parts I'll be using, then start with first disassembly of the case and preparatory modifications!
The case will be rotated by 90° so that I can get a more symmetric look with the handles at the front and back, as you have seen I have two C700M's just because the first one had a faulty LED strip and CM was so great that they sent me a second case instead of just a replacement! So I had the idea of taking the top panel from the first case and replace the bottom one with it, so now I have the same panel front and back.
Since I started using a CNC for my projects, I obviously had to start working more on 3D software than just directly on the panels, so that took a looong time to get used to and still trying to get the hang of it, but I must say I almost got used to this by now. Anyway, I start taking some measurements and doing some trial and error on all the internal pieces.
Now to the first real modifications: I took my beloved aluminum L-profiles and splattered them all around the internal frame taking advantage of all those threaded holes that the C700M offers... so handy!
This will allow me to mount all the internal panels and give me some extra clearance between those and the external ones to fit stuff like rad/fans and other fancy stuff that will come later.
The initial idea was to have what I would call "suspension arcs" attached to the handles, those would suspend the case from the floor and create some sort of orbital ring look around the case. I made a couple templates of those arc out of MDF and well, I realized it wasn't really a great idea as it looked silly no matter how I put them. So I almost totally scrapped that idea and went another way, which you'll see in later updates.
