Well this has some Great points and some bad:
Great points:
1.Adjust CPU FSB Frequency:
Youcanadjustthedesired"CPUFSBFrequency"byusing"+,key The default value of AMD Athlon™64 is 200MHz. The maximum value is 450MHz.
2.AMD Overclocking Configuration (CPU Ratio):
If the CPU is Athlon™64 FX series, the ratio range is from 4 to 25.
If the CPU is Athlon™64 series, the ratio should be set according to its model number. For example, the ratio range of 3000+ is from 4 to 9, and the 3200+ is from 4 to 10.
3.Adjust Extra CPU Voltage:
This is for adjusting CPU voltage while overclocking. Following the CPU default value, the maximum is 1.8V. The interval is 0.05V.
4.Adjust DDR Memory frequency:
The Memclock is the major part which has four different frequencies to match many kinds overclocking memory modules. The memory frequency settings includes DRAM/FSB=1/2, 2/3, 5/6, 1/1.
5.DDR Memory Voltage:
This is for adjusting memory voltage while overclocking. K8N Diamond Plus has a special design.We use jump to distinguish two level arrangement of voltage. In this way it can get maximum 4.1V for overclocking modules. As you can see the below pictures, the left one is the standard mode when jump hat is located at the top postion. The default value is 2.5V, and the maximum is 3.2V. The interval is 0.05V. As the right one, it is overclocking mode when jump hat is located at the under postion. The default value is 3.2V, and the maximum is 4.1V. The interval is 0.05V.
6.Cool running.
7.Good onbard sound.
8. plenty of space for add on cards.
One bad point at the moment but a bios update should fix the problem:
1. Double sided memory modules seem to be set to 2T and make it run at a defalt speed of 333MHz, but single sided memory models seem to be ok and can be set to 1T and run at defalt of 400MHZ.
Conclucion:
This is a great motherboard, the layout has plenty of room for PCi cards even when running with SLI instaled,the onbard sound is also very good as it uses the Creative sound Blaster Audigy SE audio,this is also a very cool running motherboard [this has been compaired to the ASUS A8N32]
The Temperature figuers listed are with the ASUS and MSI motherboards running at 2.6GHz at 1.35 volts with both cores underfull load using prime 95.and room Temperature of 22c.
ASUS A8N32-SLI Deluxe motherboard Temperature: 38c, CPU Temperature: 38c-40c.
MSI K8N diamond plus motherboard Temperature: 36c, CPU Temperature: 30c-32c.
The Temperature figuers listed are with the ASUS and MSI motherboards running at 2.6GHz at 1.35 volts with no load
ASUS A8N32-SLI Deluxe motherboard Temperature: 32c, CPU Temperature: 30c-32c.
MSI K8N diamond plus motherboard Temperature: 30c, CPU Temperature: 16c-17c.
These Temperature have been checked with two Independant sensors.
So to rap this post up now, all i can say is when this motherboard does get an updated BIOS it will be a real contender for the DFI motherboards.
Great points:
6.Cool running.
Conclucion:
