Hi everyone, so the problem is that everytime i boot the system up, it suddenly crashes with a blue screen for a split second and then restarts again and then crashes again constantly.
The issues windows was adressing me with was that it was something to do with the "MEMORY_MANGEMENT" in which i tried to adress using these methods:
1)I used Memtest86 and at first diagnosed me with millions of errors in which i thought at first was that the RAM was faulty however after removing one of the RAM modules and tested them individualy there was no errors what so ever with the modules.
This brings me to my next conclusion in which i thought it was something to do with the RAM slots on the motherborad:
2)So i tried the using the methoed in part "1" but instead switched the RAM modules between slots "A1,A2,B1,B2" after each tests in which they all passed yet agaian.
Now after these baffling test results i decided to put the two sticks togethor and run memtest again over night. First thing next morning i went to check on its progress and there has been no errors at all with the RAM modules.
After i rebooted, the computer crashed again with the same problems "MEMORY_MANAGEMENT" in which i reran Memtest86, to find a tonne of errors appearing on the screen, which it is very odd since the memtest ran overnight had appeared with no errors.
3)This time i decided to go to the BIOS to configure my DRAM settings such as bumping the volts up a notch or 2 which again failed.
After many failed attempts to log into windows i managed to log in somehow in which i made sure that everyhardware i had on my computer was fully updated with the latest drivers
as i thought this could have contributed to the problem thus i used windows diagnostic and troubleshooter to find any further problems in which "no problems where found"
4)After i ran prime95 for a few hours before finally switching the computer off before i went to bed in which the computer had not crashed or anything of that matter however the next evening back from work i turned the comp back on and GUESS WHAT it crashes again adressing me with the same problems.
I really am completely baffled. Any advice or help please ? would be very much appreciated
My specs are:
CPU: i7 860 stock settings
MoBo: ASUS Sabertooth 55i
GPU: 2x Gainward GTX460 Golden Sample_stock settings
RAM: 2x2gb corsair XMS3 1333mhz CL9
PSU: Antec TruePower 650W (modular)
SSD: Kingston V100 64gb
OS: Windows 7 64 bit ultimate edition_ in which i installed it on the SSD
HDD: WD Caviar Black 1TB
Case: CM 690 White Edition
CPU Cooler: Noctua NH_U12P SE2
Extra case fan: 2x Akasa Apache
My specs are:
