Problems with Asus A8N-SLI deluxe chipset fan
Raven said:
can STRONGLY recommend titan vga cooler.
have been using those as chipset cooler since i went nf2 and its a quiet fan last long and is quiet, im running it through a resistor which limits the fan to 3200rpm which makes it completly silent.
also the fan is fastened onto the heatsink with screws which makes it easy to change when need to.
and it isnt expensiv either, about 2 cheap pizza's ;)
http://titan-cd.com/eng/vga/cuv2abrhs.htm
Hi all! first post here! i just ordered this HSF. Are you using it on a A8N-SLI Deluxe board? I only want to know if it fits perfectly or you had to made some workaround to fit it?
Thanx and sorry about my english!
nope but im using it on a msi k8n sli-fi and it fits right fine and does not interfere with the gfx card.
the titan fan is 56mm on the diameter so if the stock fan is very small it might be a problem.
http://www.overclockers.ru/images/lab/2005/02/28/mb.jpg
the k8n sli-fi looks like this.
http://boutique.3dchips-fr.com/images/01.jpg
