I kept mine in the fridge,system was like 9 degrees when i booted it up first time on wc![]()
Cool![]()
One more thing, I heard the colour sticks to everything if you don't clean the loop every once in a while? How often would you need to rinse the liquid and re-bomb?
Looking for a good answer for this myself. I am assuming every 6 months from what I have been reading.
Oh FYI your using the gold color right? Did you get dye bombs for it? I actually ordered 2 bottles of it and ended up using almost both dyes as only using one gave a very faint gold color but I only used one bottle to fill my loop. Just some info I found out for what it's worth. I will probably be on the hunt for gold colored tubing in the future so I won't have to worry so much about cleaning the inside of the blocks. Course I think about this AFTER everything is up and running...oh well never ends I guess.
What type of RES you using? If it's multi option I highly suggest using drain and fill ports....if that is an option. made filling and draining sys really easy.
I used a primochill dye bomb,and to be honest it didnt hardly put any colour in,so have ordered another dye to go in.
don't forget biocide,and system anti corrosion protection to.
