Prepare to drool...
dave87
Hey Guys,
Just thought I'd show some pictures of the rig I built for a mate today...prepare to drool...
Specs:
P182 (I think)
Corsair HX520 PSU
Core2Duo E6600 @ 2.4ghz
Scythe Ninja HS & 120mm Fan
4gb (4x1gb) DDR2-6400 (800mhz)
BFG 8800 GTS 320 OC
P5B Deluxe WiFi
2x250gb RAID0 OS drive
1x400gb Storage drive
1xLightscribe DVD-RW (SATA)
1xDVD-RW/RAM (SATA)
One thing that surprised me was how shiny the case was:
Temps were pretty damn good, 31C idle, all fans as low as they go :)
Drooling commenced! Nice rig you put together, very clean I like I like!
I would change that HSF to be on the right side of the sink and blow out the back through the rear 120. Looks like that fan might have a hard time getting its full flow rate being as close as it is to the vid card. Just a suggestion. Cheers!
Tried that, fourth (or first, depending on which way you count it) dimm blocks the fan install. :(
(There is actually a 120mm fan at the top too, which spins the same speed as the back one ;))
Ah sweeeeet mate, good lookin' rig you built there. Cheers!
Not bad I guess
That case (with the door open) reminds me of the really old chunky Dell + IBM server cases.
Grey plastic front with black metal sides :confused:
Shame about the CPU Fan placement aswell (even if it couldn't be avoided) :(
Urgh, it`s the only concern really, the whole build looks sweet tbh - and the shine ;)
With the little clearance between the fan and the gfx pcb, I don`t feel the draw is going to be that good, I`d almost be tempted to put the fan on the top side and suck air through the fins upwards. Think u`d like about 2" of clearance to be effective. - then u`ll have it fighting with the rear fan for draw.. ugh.
I dunno, if u`r temps are good, then why change from what u got tbh :)
8800 FTW ! - very nice ;)
Nice :), im thinking about this case for a few of my upcoming builds
(Brothers, My own gaming rig, and maybe 2 other friends... busy busy :))
