WebMaximus
Just bought a Corsair H100 and was wondering if someone knows how good the pre-applied thermal compound is and if it's worth trying to get rid of it and instead apply your own Arctic Silver 5? And if yes the never ending million dollar question...when applying your own thermal compound like Arctic Silver 5 should you apply a thin, even layer covering the whole CPU cooler block or should you just apply a lump in the middle (or maybe in the form of a cross) and then let it spread by itself when you mount the cooler onto the CPU? I've seen and heard so many schools on this subject but I never really understood what is the best method doing it...?
Anyone in here tried both with a H100 and can share the difference if any it made?
I'll be cooling a 2700K that I hope I'll be able to overclock to about 5 GHz with the H100 and I'll also be adding 2 additional fans to the H100 for a push pull config for maximum performance.
Thanks in advance for your input guys!
