The watch I posted last week has been on my wrist for a few days now. Honestly, you wouldn't be able to tell it only cost €80.
thats is a smart looking watch, dont knock the price cos these are the exact kinda watches i used to use seiko - casio - citizen , used to get them all the time and in that price range and they look like they cost double that, only reason i used to go through so many is cos when spear fishing or diving used to wreck em on the rocks even had octopus try crack a seiko i had but it only managed to scratch n bend the strap, face of it nothing happened , but it took a ''LOT'' to kill them of most of the time they didnt even break but cos they got so battered or loose them at sea i got a new one and you will see what ever you put it through unless you get a diamond tipped tool and really go at it it will never scratch
you will have that for ages![]()
also thanks guys for the well wishes on the bike it is a life changer
I would bottom feed it and use a blow out cap valve on the top.
They are nice though. I had a 140mm one (mine was missing all the plugs ffs) and it was really nicely made.
This one is also 140mm tall and at only £7 delivered![]()
What are the holding pieces like? (the clamps) are they clear or ratchet (like Bitspower). I paid £12 IIRC but got 120mm fan holding bars too if you wanted to mount it to a fan.
TBH the quality was no different to my BP res. However, my BP res includes a feeder tube that is cone shaped (if you top feed it, to stop cyclone) and the bottom has a diffuser piece in it again to stop cyclone. It also came with two blow out pressure valves and two premium BP caps (which are £8 each). Then because they sent me the wrong res (I ordered red they sent clear) they sent me two black premium caps again worth £8 each lmao. Not bad for £25 inc![]()
