sorry for the delay had some issues regearing the comp lol mostly hardware issues some my fault others bad parts bought.
First off I got robbed a box full of foam peanuts???
LOL under all that packing material
got black and white cause i wasnt sure how I was going to do it at the time wanted the parts on hand to bang it out once decided.
Primochill Advanced LRT in Onyx Black and Elegant White 1/2 x 3/4
Monsoon Chaingun compression fittings black ring white rods
Monsoon 45degree rotary fittings in white and black 4 of each
Monsoon 90degree rotary fittings in white and black also got 16 black disk inserts for the ends as well as 16 white disks
Monsoon MMRs reservoir system consisting of
150mm and 100mm frosted white reactor core tubes
150mm and 100mm black tension rods
d5 mount end cap white
coupler white (for joining the 2 tubes together)
end cap white fill port
Monsoon mounting kit x 3 white. (only ended up using 2)
Alphacool Eispump VPP755 ( the new D5)
Alphacool Monsta 360mm rad
Bitspower 50mm extensions 2 ea white black
the pump/rez parts
assembled
mounted
running (you may notice thats a different mobo than the mounted pic thats where my issues started that were part my fault part bad hardware.
Closed up and running smoothly now
along with a shot of me ugly mug lol
Now for what i was on about with faults lol heres mine still dont know how I buggered it so badly
So I grabbed an Asus Tuf Mark 1 at my local B&M and fought it for 2 days trying to get it working all along thinking my cpu was a dud due to artifacting and lack of display even thru IGPU finally borrowed a buddies 6600 and had the exact same issues so confirmed bad mobo returned it for the MSI Z270 Gaming M7 thats in the pics now.
